PAC code ‘Not Created’
Callum Gilmour
Hi Tom, I came across your message to a lady who had the same problem as me where she had left ID and pac code had to be sent via email but it just said ‘Not Created’ where the pack code would be. This has happened 3 times to me now and customer services keep doing the same thing which isn’t working. Did you manage to solve the problem for this lady and if so you could help me with the same? Thanks
Best answer by Tom
Hi @Jennifer Timoney
  • 12540 replies
  • June 2, 2023
If you’re leaving iD Mobile, then have you tried sending a text message “PAC” to 65075 @Callum Gilmour using your iD SIM card?
You’re supposed to receive a reply from iD within a few minutes, with your PAC.
Callum Gilmour
  • June 2, 2023
Yes but I can’t do that anymore as Ive terminated my contract and can no longer call or text with my ID sim card
  • 3099 replies
  • June 2, 2023
If you’ve terminated your contract and the account was closed (line terminated), then your number is lost. You cannot port a ceased line’s telephone number.
Mohammed H
  • 7962 replies
  • June 2, 2023
Hey @WelshPaul,
We’ve implemented a change as per OFCOM’s guidelines (EECC) which allows customer’s to get a PAC code up to 60-days after disconection.
@Callum Gilmour,
Paul Scott
  • July 16, 2023
I have the same issue, number disconnected and unable to attain PAC code. Please advise Mohammed.
Mohammed H
  • 7962 replies
  • July 18, 2023
Hi @Paul Scott,
  • August 15, 2023
Mohammed wrote:
I am having same issue could you please private message me
  • 8552 replies
  • August 16, 2023
Hi @lewispoke8
  • October 27, 2023
Hi, I’m having the same issue. My number has been disconnected due to the end of contract. I need a PAC code please help.
  • 12540 replies
  • October 27, 2023
Hey @Abdul786, was your disconnection within the last 60-days?
If yes, then iD should be able to give you a PAC, as per the post here by @Mohammed from iD Mobile.
You might need to speak to ID customer service through social media using Facebook Messenger, or X (Twitter) DM, and refer them to this topic.
  • October 27, 2023
Ok
  • October 27, 2023
Thank you just got it sorted.
  • 8256 replies
  • October 30, 2023
Hi @Abdul786,
Glad to hear that the issue is resolved.
Please get back to us if you require further assistance.
  • November 28, 2023
Please can I have a PAC code for the same reason, my contract only ended today but my PAC code expired yesterday
  • 8256 replies
  • December 3, 2023
Hi @e.w,
Is your account disconnected or is the contract still active but past the minimum term?
If the account is still active please text PAC to 65075 from the number you require the PAC for.
Mohammed wrote:
Hey @WelshPaul,
@Callum Gilmour,
Hello @Mohammed I am facing the same issue. My account was terminated on 29 Dec 23 and I'm unable to generate a PAC code. Can you please send me this message so I can get my PAC?
  • 8552 replies
  • January 4, 2024
