F.A.Q.
How can I check the network coverage in my area?
  • August 12, 2021
  • 41081 views
iD Mobile
You can check the signal strength in your area with our helpful coverage checker, provided by our network partner Three UK:
How does it work?
To check the signal strength in your area, you can:
  1. Click here to open our coverage checker.
  2. Enter your postcode.
  3. Tap ‘Check coverage’.
  4. Tap 4G or 5G to see your coverage.
Use the interactive map to zoom in and out and move around. Dark Pink means you can expect signal indoors and outdoors. Light Pink means you can expect signal outdoors only.
Please note: Although we try to make these coverage results as accurate as possible, the information is only a guide. It doesn't guarantee availability in a particular location. The roll out plans are updated regularly and may change over time.
4% found this helpful
