How I can change plan with unlimited data for 1 month contract?
chamge plan
Best answer by Daz_S
Hi there
Does this help?
And follow the instructions.
Note on the above link:
If you’re a Pay Monthly customer, you cannot change to a plan that is cheaper than your original plan, as you still have to pay off the remaining balance for your phone. You can swap to a plan that includes more data at a higher cost – and if it doesn’t work out for you, you can change back to your original plan (as long as it is still available).
Log in to the iD Community.
Social Login
Log in with FacebookPlease enter your email address. If it matches our records, we'll send you instructions to reset your password.
