I’m not due for an upgrade for another year but have seen an ID mobile contract for the iPhone 15 pro max that I would like to sign up to. I’m happy to pay off my remaining current contact with ID but I want to keep my number and put it on my new plan. Is this doable? Everywhere which says early upgrade is max of 2 months early even though I’m happy to pay the difference.
Early upgrade/ending my plan
Unfortunately, it’s not possible
The only way to pay-off your 24-month minimum term iD contract is to get a PAC and use it, or give your 30-day cancellation notice.
Log in to the iD Community.
Social Login
