Hi All, if I switch my ID mobile plan will any data rollover from the old plan be applied to the new one? Is this dependant in any way on the timing of the switch? Thanks
rollover on switching plan
Best answer by Kash
Sorry, you can't roll over unused data from the billing period when you changed plans. Instead, your Data Rollover will re-start at the beginning of your new plan.
You won’t have any data rollover until the second month of your new plan.
Log in to the iD Community.
Social Login
