Hi there, I'm looking to upgrade to/pre order the s25 ultra, however I am currently with the three network.. If I was to buy the s25 ultra and wanted to switch to id mobile but keep my number, would this mean that my three sim would be useless till I recieve the sim from id mobile or would it be something I can do once I recieve the sim? I've never done something like this before so I'm not sure how it all works.. Also would the new sim be delivered with the phone or?
s25 ultra pre order and switching networks
You need a PAC to transfer a mobile number from one service provider to another,
When you’re ready, just ask Three for a PAC (for the number you want to keep) and give this to iD Mobile.
This community article might help.
Rich Text Editor, editor1
Editor toolbars
Press ALT 0 for help
Log in to the iD Community.
Social Login
