Hi everyone, I am Emmanuel Katto and I'm experiencing some issues with my data speeds on my iD Mobile plan. I've got the 'Unlimited Data' plan and I'm finding that my data speeds are consistently slow, especially when trying to stream videos or music. Has anyone else experienced similar issues? Are there any specific settings or troubleshooting steps that I can try to improve my data speeds?
Thanks in advance!
Emmanuel
Hey there @emmanuelkatto, thank you for reaching out.
We're very sorry to hear you're having issues with coverage.
Please take a look at both of these. If you believe you should be experiencing better signal than you are, or if the networks status checker on Three's website isn't showing any upgrades or maintenance, then please do let us know.
