How much will I be charged for Roaming?
Contents:
Roaming costs vary depending on where you are visiting and how you are travelling. Select your destination type below to see the specific charges.
Inclusive Roaming (50 Destinations).
In these destinations (mostly EU/EEA countries), roaming is free. You can use your UK minutes, texts, and data (up to 30GB) at no extra cost.
However, if you use up your monthly allowance or hit the 30GB roaming fair usage limit, you will be charged the standard out-of-plan rates below:
| Roaming | Pay Monthly | Pay As You Go |
| Calls to UK* | £0.40 | £0.40 |
| Calls to Inclusive Roaming destinations* | £0.40 | £0.40 |
| Calls received* | £0.00 | £0.00 |
| Texts to Inclusive Roaming destinations** | £0.14 | £0.14 |
| Texts to UK** | £0.14 | £0.14 |
| Picture Message (MMS) sent** | £0.55 | £0.05 |
| Internet and Data (Per MB)*** | £0.10 | £0.10 |
* Price per minute,
** Please note: MMS charges vary. For further information, refer to Terms & Conditions.
*** Data is charged or deducted in one kilobyte (KB) increments and any part KB used will be rounded up to the nearest KB.
Roam Beyond (50 Destinations).
If you are travelling to a Roam Beyond destination (such as the USA or Australia), your UK allowance does not apply. We recommend purchasing one of the following add-ons to give you data at the best value and avoid expensive per-MB charges:
- 2GB for £5 (Valid for 1 day).
- 10GB for £20 (Valid for 5 days).
- 20GB for £35 (Valid for 10 days) – Best value: works out at just £3.50 per day!
Check out the Community article below for more helpful information on how to purchase a Roam Beyond add-on.
Please note: If you choose not to purchase an add-on, or if you run out of your add-on data, standard roaming rates will apply. Use our Rate Checker to see the standard costs for your specific country.
Rest of World.
For any destination not included in the Inclusive or Roam Beyond zones, you cannot use your UK allowance or add-ons.
You will be charged for every minute, text, and MB of data you use. These prices vary significantly depending on the country.
Click here to check the specific rates for the country you are visiting.
Ships, ferries, cruise liners and in-flight
Using your phone at sea or on a plane can be very expensive. Ferry, cruise and airline operators often run their own satellite-based phone networks, which cost far more than land-based connections.
We recommend keeping your phone in flight mode until you’re back on shore or have landed.
| Roaming at sea and in-flight | Cost |
| Calls to UK numbers | £6.00 per minute |
| Calls to ships, ferries, cruise liners and airlines | £6.00 per minute |
| Calls received | £1.50 per minute |
| Texts to UK numbers | £1.20 per message |
| Texts to ships, ferries, cruise liners and airlines | £1.20 per message |
| Picture messages (MMS) sent* | £0.60 per message |
| Internet and data** | £9.60 per MB |
* MMS charges vary. For more information, see Terms & Conditions.
** Data is charged or deducted in one kilobyte (KB) increments. Any part KB used is rounded up to the nearest KB.
