can I use WiFi
I am going to Morocco, which isn’t covered by iD free roaming.
Am I right in assuming that there are no charges if I use WiFi? This is not explained.
If so, providing I use 'airplane mode' when I am out of reach of WiFi, I can avoid roaming charges.
Okay @cristofa, iD Mobile don’t provide a Wi-Fi network service.
The iD Mobile roaming charges for Morocco are high, so better/cheaper sticking to any local Wi-Fi networks, which are free to use.
To avoid out-of-plan charges in Morocco, just set your iD account bill cap to £0.
  • 12262 replies
  • July 15, 2024
  • 8358 replies
  • July 29, 2024
Hi @cristofa
As @andewhite suggests, Wi-Fi would be absolutely nothing to do with iD Mobile and only to do with your device.
In short, yes, if you find Wi-Fi networks while roaming, you can use it. iD wouldn’t stop that.
