Klightley1
Aug 14, 2026 2:28 PM UTC
Can't roam abroad in USA despite having purchased a roaming package. please help.
I'm in Las Vagas. I've purchased a data roaming addon but i can't conbect to and oprator here. I've resrated my phone and few times, addded flight mode and turned off to try and find an operator. I've tried to find an oprator manually but all that's selected is not linking. Please help. I really need to use my phone abd currently can only do so in the hotel. All my roaming is turned on. I've followed all instructions from your website advice.
    Owethu M
    Aug 15, 2026 1:33 PM UTC
    Hi ​@Klightley1,
    Please check link below to see if the handset and account is set up correctly:
    I'm abroad and Roaming is not working. What should I do? | iD Mobile Community
    Owethu
    Klightley1
    Aug 15, 2026 4:07 PM UTC
    Thank you for the reply. Yes, i've tried all of that and still not working. I don't know what else i can try.
    Decembersangel72
    Gold Contributor
    Gold Contributor
    Aug 15, 2026 11:42 PM UTC
    Hi ​@Klightley1
    Unfortunately iD Mobile rely on their US roaming partners providing network services when you’re in the USA.
    In theory you can use your iD SIM to roam in the USA, assuming everything is setup on your handset with the iD SIM, and your iD account, to allow roaming in the USA to work.
    When you arrive in the USA, if everything is configured properly you should receive an iD Mobile roaming rates SMS text message.
    If not, then roaming in the USA, with your iD SIM card, could be problematic.
    The networks that you can connect to with your roaming add-on can be found here:-
    Turn off automatic network selection in your phone settings and manually try to connect to one of iD Mobile's US partner networks
    Scroll down to ‘ Roam Beyond Destinations’ and expand ‘United States (USA)’ to see the which networks can be used.
    If you can connect to one of these then you should be good to go.
    If you don’t mind the inconvenience, you can always pick up a pre-paid SIM in LV and use that for the duration of your visit and then replace your iD SIM once home.
    Hope this helps x
    Hosai W
    Aug 17, 2026 12:50 PM UTC
    Hi ​@Klightley1,
    Please try connecting to AT&T and T-Mobile this is the networks that we support in USA.
    Hosai
    Klightley1
    Aug 17, 2026 6:58 PM UTC
    This didn't work either. I've tried all operators everyday and no luck. I connected to a network and had roaming when i went on a day trip to another state but stopped when i returned back to Vegas.
    Marquerita T
    Aug 18, 2026 2:57 PM UTC
    Hi ​@Klightley1.
    Thanks for trying those steps and for the update.
    Since you’re still not getting service back in Vegas after it worked while roaming, please contact us directly via live chat at https://www.idmobile.co.uk/live-chat so our team can review your account and check your roaming settings and network registration.
    Marquerita
    The iD Mobile Team
    Oct 29, 2026 11:27 PM UTC
    I’ve tried all these as well and it still doesn’t work! Help
    Oct 29, 2026 11:28 PM UTC
    This also doesn’t work for me. ID mobile please help
    Marquerita T
    Nov 3, 2026 11:32 AM UTC
    Hi ​@Ginger Allie.
    Thank you for sharing. I am sorry to learn this is not working for you.
    Can you please tell us where you are roaming?
    Marquerita
    The iD Mobile Team
