checking my roaming balance | iD Mobile Community
  • September 22, 2024
  • 164 views
David Dowse
I rarely use my data allowance when I am in the UK and have built up a large balance. However, when I’m abroad, I’m only able to use 30 GB of this balance.
I rarely use my data allowance when I am in the UK and have built up a large balance. However, when I’m abroad, I’m only able to use 30 GB of this balance. How do I check how much of that I’ve used?
Best answer by Kash M
Hi @David Dowse,
Unfortunately we don’t have a way of checking only roaming usage.
I would advise to make a note of your usage before using it and you can then keep track of it.
You can also set data limits on your handset via your data settings.
  • September 25, 2024
Hi @David Dowse,
