I've just been abroad on holiday and on returning my data remaining on the app shows 197gb of 100gb which is a bit concerning. My bill amount shows the correct amount. Should I ignore this?
Data remaining
Best answer by Kash M
It looks like the 194.7GB is the remaining amount.
The amount showing before your allowance (100GB) is the remaining amount of allowance you have left to use.
If you rolled over any unused data you’ll see a higher amount than your usual 100GB.
I hope this helps.
Log in to the iD Community.
Social Login
