Data Roaming in Japan
  • September 5, 2024
  • 1243 views
Hello all,
I am in Japan right now and transited via Hong Kong. When I was in the HKG airport trying to connect to the airport wifi, I received Rate Advice messages that I am roaming. I immediately went to ID mobile website just to realise the roaming feature was on, but I am sure I didn’t turn on my iPhone’s data roaming. My mobile data was not on either. So I turned off the ID mobile roaming feature as well as setting my bill cap to 5 pounds (should have left it at 0 pound but made a mistake). Then I continued using the HKG airport wifi. When I got to Japan airport another Rate Advice message popped up again - I have noticed both messages seemed to pop up when I turned off airplane mode trying to connect to airport free WIFI, but I made sure I didn’t turn off the mobile data as well, and the data roaming toggle on my iPhone is never on.
I checked with customer services and they said from their end the last interaction (the time I used my mobile data) was when I was getting up to go to the UK airport, but strangely enough I was using my phone to browse the internet whilst travelling to the airport, but those interactions were not showing up on their end, that’s why I am still a bit worried if their records were up to date when I asked if any data roaming charges have been incurred. Well their answer was no because the last interaction was in the UK, not abroad.
On a side note, I read articles that for data roaming to work, both the ID Mobile app/website “data roaming” feature, and the phone’s “data roaming” have to be on, without either of them, data roaming should not happen. To test it I was connected to Wi-Fi but I turned on mobile data (with data roaming feature off) and the iPhone’s “current period roaming” counter jumped for 1mb. Is that even relevant to how much ID Mobile may charge me on data roaming?
So I guess my question is, in this case, am I safe to say I won’t be charged any data roaming fees? I am quite worried about this so I don’t want to wait till my next bill to come to then know the answer. I want to be rest assured that I won’t be charged anything (but luckily the customer service agent said they have noted this down and if anything comes up they will be happy to waive this for me).
Any help appreciated. Thank you!
You pay for your plan monthly in advance, and any out-of-plan charges are shown on your next bill, @yuendumthe.
You’ll have to wait for your next bill, sorry.
  • September 6, 2024
Hope you are enjoying your trip.😊
Since both ID Mobile roaming and iPhone data roaming are off, and you're not using mobile data, you should be safe from data roaming charges. The Rate Advice messages appear because you connected to a foreign network, but without data roaming on, no charges should apply......…
Have a Great Day…..
  • 12167 replies
  • September 6, 2024
Okay @yuendumthe, to avoid any out-of-plan charges, such as data roaming fees, just set your iD account bill cap to £0.
This iD online article might help.
  • September 6, 2024
thanks . I am trying to see what will happen this time. I don’t think setting up the cap to £0 retrospectively after things have happened would work?
  • 12167 replies
  • September 6, 2024
You’ve said the bill cap for your iD account was set to £5, so you wouldn’t be charged more than £5 in any given billing period for roaming use.
You also mentioned using 1MB of roaming data during your experiment - if this is correct, it wouldn’t cost more than £1, @yuendumthe.
  • September 6, 2024
Thanks. When I used roaming data will the bill reflect immediately? I am still seeing my usual bill which is £8 right now. So can I safely assume I didn’t incur any data roaming fees?
  • 12167 replies
  • September 6, 2024
  • 8225 replies
  • September 10, 2024
Hi @yuendumthe
As @andewhite suggests you may need to await the next bill for out-of-allowance charges to appear, however if you set your bill cap to £5 before you used enough to charge £5, that’d be the maximum you’d pay.
If you set the £5 bill cap AFTER you went over £5 of charges, it’d stop you completely from doing anything charging further.
