data roaming not working in tenerife | iD Mobile Community
  • November 18, 2024
  • 241 views
Forum|alt.badge.img
Hi, data roaming is not working. Says you have lost connectivity because you left your home network with it switched off, but it is enabled in the app & the swipe down screen on my Samsung S21. Having read some replies I looked at the phone settings but it says there is no sim in sim manager and it's greyed out and all of mobile networks is greyed out. Any advice please.
Best answer by Steevo
Thanks for the responses. I contacted idmobile and they said it was a faulty sim, sent me an esim and all is working now after a few resets and some adjustments. Cheers.
  • November 18, 2024
Hey there ​@Steevo, welcome to Community!
Sorry to hear that. Can you send a screenshot of what you’re seeing please?
Daz_S
  • November 18, 2024
Hi there ​@Steevo
Just checking. Did you enable roaming on your iD account prior to leaving the UK?
That’s not the same as having roaming enabled on your phone.
If both were set before you left (although the phone setting isn’t that important before leaving) then have you tried a manual network selection rather than letting the phone auto connect.
Forum|alt.badge.img
  • November 18, 2024
Daz_S
  • November 18, 2024
That’s good to hear ​@Steevo
Enjoy your phone, but enjoy Tenerife more as its ruddy freezing here at the mo 😨
