data roaming option greyed out on samsung s23 fe
Been online chat twice and not much help. My phone option for data roaming is greyed out, I’ve been to Spain and corfu but couldn’t turn it on so I could use emails, WhatsApp etc without wifi.
the people on the chat said they’d pass it to technical but they were no good either. Asking me to try it abroad even though I’ve told them the option is greyed out. I’ve put my sim in the old phone and that works with no option. Therefore how do I get round this
  • 8765 replies
  • March 5, 2025
Hi ​@Doany1972
Sorry to hear this, have you tried a network settings reset?
For iPhone;
For most Android;
For Samsung;
  • March 5, 2025
Hi Tom.
yep I tried all these, the annoying thing is the sim works and data roaming too on my old phone. There’s obviously a problem with the phone as others have asked the same within the community without seeing a reply.
  • 8765 replies
  • March 5, 2025
Hi ​@Doany1972
What’s your new phone?
What’s your old phone?
MZone
  • 1268 replies
  • March 5, 2025
S23 FE is not on the list of phones compatible with iD network so they won’t be able to provide technical support for it.
  • March 5, 2025
My old phone was Samsung galaxy A32
my new phone is Samsung galaxy S23 FE
if it’s not compatible how or why have I been sold it from ID Mobile?
MZone
  • 1268 replies
  • March 5, 2025
Fair maybe they haven’t updated the list - my bad
MZone
  • 1268 replies
  • March 5, 2025
Just had a quick look on the Samsung forums and seems to be an issue after the latest software update. You might get better support posting on there. Suggestions include toggling aeroplane mode on/off and switching to 4G.
  • 2497 replies
  • March 6, 2025
Thank you ​@Doany1972
Can you please try the suggestions from ​@MZone and let us know how you get on?
Also, are you currently in the UK at the moment and does roaming show as enabled in the iD Mobile app?
Natalie
I've just got back from Spain and I've had the same problem. Ihave a Samsung Galaxy S23 fe. My son looked at it all and found that unless you are with Vodafone, ID mobile doesn't work!
Even when you toggle roaming button before you go out, it does go green, but when you land in Spain that's where it all stops!
I thought it was something I'd done.  I'll be changing companies i think!
I assume this is why they have cheaper prices for contracts.
They DO NOT tell you this information when you buy the contract, I suppose they might do if you asked the question beforehand. I hope this helps!
Claire
  • 6659 replies
  • March 17, 2025
Hey there ​@AmethystUnicorn, we’re sorry to hear about your poor roaming experience using our network.
However, roaming should certainly work whilst in Spain.
If you’re back home now, it’d be difficult to troubleshoot I’m afraid, so next time you go abroad, please get in touch immediately so we can investigate your issues further for you.
Of course, if you’re having issues in the UK now, please let us know.
  • May 22, 2025
I had the same problem, when i moved my sim to the new phone it wouldn't let me select data roaming, and then i realised i couldn't select anything on the mobile networks screen, Access Point names and Network Operators was also greyed out. However in my old phone it was fine.
Mine seems to be a problem with the dual sim card option. If I put my sim card in slot 1, iit doesnt show as registered but works fine except for the data roaming. So i downloaded an eSim from the app and that gave solved the data roaming issue but it said emergency calls only. So i’ve now disabled the eSim and put my sim into slot 2 and that works fine. So perhaps check your sim and see if the problem is with that?
Live chat also only gave me very basic help, its a shame they can’t be a bit more supportive with these issues - at least suggest a few ideas!
