Data roaming reset | iD Mobile Community
Data roaming reset
  • August 6, 2024
  • 331 views
I’m roaming in france for 18 days and my plan renews 8 days into the trip. Does this mean i can use 30 gb under fair usage for the first 8 days and then another 30gb for the next 10? Or am i limited to 30gb over the whole trip even with my plan renewing?
The iD inclusive roaming feature allows you to use up to 30GB of your UK plan data allowance, while roaming in France, @emgogs.
It’s up to 30GB of your UK plan data allowance, so when your plan renews so does your inclusive roaming data allowance.
  • August 6, 2024
  • August 6, 2024
Thank you so much!
  • August 12, 2024
Hi @emgogs
I’d recommend the same as @andewhite above, the 30GB fair usage allowance renews with the normal allowance period.
Thanks for the help here, @andewhite.
