data roaming toggle not visable
I am overseas and have an iPhone . When I go into mobile services the “ data roaming” toggle is not viable ( it was when I was with Vodafone) . I can’t download data when not on Wi-Fi
Am I missing something ?
Best answer by WelshPaul
Have you enabled roaming from within the iD Mobile app ​@Ianworkman?
Plan > Manage your iD services > Roaming
The following guide might be of some use to you:
https://www.idmobile.co.uk/help-and-advice/roaming-advice
  • 3054 replies
  • April 16, 2025
Siân
Forum|alt.badge.img+8
  • 1323 replies
  • April 16, 2025
Hi ​@Ianworkman
Sorry to hear that you are having some issues with roaming. Do you have the iD app? You can check it is enabled from there?
  • April 17, 2025
Hi yes the toggle in Id mobile has been enabled but still doesn’t show
  • 3054 replies
  • April 17, 2025
Did you do all this prior to going abroad? The roaming guide information states you must enable roaming before going away.
Only things left to try are a reboot of the phone or perform a network reset.
  • 8408 replies
  • April 17, 2025
Hi ​@Ianworkman
Have you tried the above from ​@WelshPaul?
It’ll be worth using manual network connection too instead of automatic.
