Data Usage
  • November 8, 2024
  • 393 views
Can I use my data allowance whilst in Dubai?
Unfortunately @Ru55ty, you can’t use your UK data allowance while roaming in Dubai.
Using your iD SIM for mobile data in Dubai will cost £9.60/MB, which is equivalent to £9600/GB - ouch!
  • 12380 replies
  • November 8, 2024
  • November 8, 2024
What are my options for using my phone whilst out there without a bill that needs a mortgage to pay it
  • 8408 replies
  • November 8, 2024
Hi @Ru55ty
No, while in Dubai you’d be charged extra for usage according to what you use, we’d recommend checking the following;
  • 12380 replies
  • November 8, 2024
Okay @Ru55ty, if your mobile phone is eSIM capable you could try a data-only eSIM with a travel plan for UAE (i.e. Dubai), which should be much less than using iD roaming data.
Alternatively, get a local SIM upon arrival.
