New to ID and I switched due to the generous 30GB roaming data included in the 60GB plan.
I know unused data rolls over but does any unused Roaming portion also rollover?
Best answer by Matthew T
Hey
No, Roaming is capped at 30GB per month as per our Fair Usage policy,
https://www.idmobile.co.uk/help-and-advice/eu-roaming/fair-usage-policy#after-june-2023
