imessage international cost?
Does it cost me to send an imessage to a uk number from overseas (Sri Lanka)? I also have a uk number. And would it cost them to send an iMessage to me?
does it matter if WiFi is used or cellular data?
Best answer by Natalie W
That is correct ​@schitnavis123.
If the person is using WiFi, the same rules should apply but it would be worth them checking with their provider to be sure.
Nat
  • 12167 replies
  • January 3, 2025
You can send an iMessage using a cellular (mobile data) or Wi-Fi network connection, ​@schitnavis123.
The Apple iMessage service requires an Internet connection to work - either using the data allowance of your cellular (mobile) service provider’s plan or a Wi-Fi network connection.
  • 3801 replies
  • January 3, 2025
Hey there ​@schitnavis123, thank you for reaching out.
If you’re in the UK, it shouldn’t cost you to send iMessages, as these are sent via data/Wi-Fi, and not via SMS.
You will need to ensure both yours and their Wi-Fi/data can send/receive the iMessage however, otherwise it may send as a regular text, and then you’d be charged for that.
  • January 3, 2025
Thanks all. So if I’m in Sri Lanka and use wifi to send an iMessage to a UK phone, I won’t be charged? But I will if I use cellular data? What rules applies for the person in UK sending iMessages to me?
Forum|alt.badge.img+21
  • 2101 replies
  • January 6, 2025
Nat
