International Roaming Charges - Australia & Antigua
  • January 7, 2025
  • 1181 views
I’m visiting Australia and Antigua within the next 6 months, will I be charged roaming fees?
Both of the above are on the international roaming list, but I’m not 100% certain this means I won’t be charged when visiting.
Best answer by Kash M
Hi ​@Nuala Turnbull,
Unfortunately both locations don’t include inclusive roaming so you’ll be charged for usage.
You can find the charges at the link below:
  • January 7, 2025
Hi. I was trying to speak to somebody because this is driving me nuts trying to find information on the website but maybe you can help?
Is there a link that I can just go to and upgrade my mobile so that I don’t get charged loads while I’m in Antigua next week?
Thanks in advance!
Michael
Siân W
Forum|alt.badge.img+19
  • May 11, 2025
We do have Roam Beyond add on’s, but this doesn’t currently include Antigua I’m afraid ​@Michael Curry
An upgrade wouldn’t change any charges you may receive, but you can check our the roaming charges here - International Calling & Roaming Charges | iD Mobile Network
If you would like to control how much you spend, I would advise to set your bill cap, if you haven’t done so already - How do I set or change my Bill Cap? | iD Mobile Community
I hope this helps, and hope you have a fab trip!
