Mexico Sept 2024
  • August 18, 2024
  • 80 views
I travel to Mexico next month, if I turn my voicemail off and my data roaming, will I still be charged for any incoming calls? I don’t plan on answering the calls, I plan on buying a different sim to make calls/texts back home. Just need to know if I will be charged for answering my phone?
  • 8369 replies
  • August 23, 2024
Hi @Loukeal
You’d only be charged for incoming calls that you answer, if you don’t answer it, you wouldn’t be charged.
My best recommendation to avoid extra charges is to set a bill cap you’re comfortable with.
