Mobile data not working in Italy
Hello, This is my second trip to Italy with no data. In March I could get anything, so ordered new SIM. Still no data now I’m back in Italy. Is there anything I can try to get it working? iPhone 12 Pro
If calls and texts work in Italy, the APN value might be incorrect, @ajdmcr.
The correct value is “id” (in lowercase).
  • 12288 replies
  • June 15, 2024
Maybe worth trying a NETWORK RESET on your iPhone, @ajdmcr.
  • June 16, 2024
Thanks, I tried that and it’s still the same - 4G / 5G flashes up next to battery then disappears. I’m going to try sim in another phone, then contact ID tomorrow if no better.
  • 12288 replies
  • June 16, 2024
  • 8369 replies
  • July 3, 2024
Hi @ajdmcr
How did you get on with trying the SIM in another phone?
  • July 3, 2024
Sorry, meant to reply to andewhite earlier.
i had a dig about in settings, trying to find ANP. Couldn’t find it, but looking through different settings, I did find a VPN profile from Lebara, my previous supplier. Deleted this, and mobile data started working.
Thanks andewhite for taking the time to help, much appreciared!
  • July 16, 2024
Hi @ajdmcr,
I’m glad to hear that your query is resolved.
Thanks for sharing the fix as it may help other users.
Please let us know if you require assistance in the future.
