my plan
I don't see my plan roaming and wifi calling on. Id mobile app
Best answer by Daz_S
I think I know what you mean
This means that I do not need to show my plan on the website.
The iD Mobile app and the iD Mobile online portal are the same thing in regards to the account. One uses an app you install on a phone or tablet or other handheld device, whereas the 2nd option uses a URL and is not a website but a web based portal.
mobile ID This means that I have this package.
Yes if that’s what you see on the App (or online) then yes that’s your package
Minutes, SMS and data (up to 30GB) to 50 destinations worldwide
Yes 50 worldwide destinations is what it says, just be mindful that only EU (and a few non EU) countries currently form part of iD’s free roaming. Some other destinations are chargeable for ALL use of your phone.
Daz_S
Gold Contributor
  • Gold Contributor
  • 1627 replies
  • November 12, 2024
Having roaming and WiFi calling on shouldn’t have any bearing on the iD Mobile app, meaning neither should stop it from working @mosul1974
But if you can’t use the app, why not use the online method instead, you can do all the things the app does on there too?
https://my.idmobile.co.uk/
  • November 12, 2024
I want to see my plan, how many GB I have and how many countries to use it in? why I can’t see you.
Daz_S
Gold Contributor
  • Gold Contributor
  • 1627 replies
  • November 12, 2024
So you can’t view how many GB you have on the iD Mobile app AND the online link I posted?
You need to look for roaming on their site for this info:
https://www.idmobile.co.uk/help-and-advice/eu-roaming
Also on that link you can check other non EU destinations.
  • 3801 replies
  • November 12, 2024
Hey there @mosul1974, welcome to Community!
If you want to view your plan, you will simply need to login to the iD Mobile app/website. This should show you how many GB you have left and all your plan details, as well as being able to turn on/off data roaming etc.
Wi-Fi calling should be an internal phone setting you can turn on/off via your phone’s own settings.
Finally, you can see where inclusive roaming can be used via the link below:
  • 8175 replies
  • November 12, 2024
Hi @mosul1974,
Have you checked your iD Mobile app home page to check your allowances?
You can see the EU inclusive roaming destinations at the link below:
  • November 12, 2024
This means that I do not need to show my plan on the website. mobile ID This means that I have this package.
Daz_S
Gold Contributor
  • Gold Contributor
  • 1627 replies
  • November 12, 2024
  • December 9, 2024
Hello l haven't received my £35 voucher. Can I find out when I can receive the voucher?
Daz_S
Gold Contributor
  • Gold Contributor
  • 1627 replies
  • December 9, 2024
  • 8175 replies
  • December 10, 2024
Hi ​@mosul1974,
Please let us know if you require further assistance and we can advise further.
