No roaming. Chat agents not helping
Peter Connick
In Spain. Roaming usually works OK here. Samsung M31. My wife has the same phone also on ID hers works perfectly.
When on Movistar can't make/receive calls or texts. Sometimes it goes automatically to Vodafone ES and works. (Not an ID partner).
Phone WILL NOT go to manual network select
Have spent more than two hours with chat agents. They all keep telling me to change manually to Yoigo. Phone will not change from automatic to manual.Yesterday Agent Maurice dumped my chat after 90 minutes.
I also think that the agents are  helping several.clients at the same time.
Anybody got any ideas please? It seems the agents Can't help.
This community article might help, ​@Peter Connick
This community article says Vodafone, Telefonica, Xfera, and Orange are the iD roaming partners in Spain.
  • 12421 replies
  • April 11, 2025
  • 4541 replies
  • April 12, 2025
Hey there ​@Peter Connick, sorry to hear this.
We hope the kind advice from ​@andewhite has been able to help, and we do recommend taking a look at the articles above.
If issues are persisting, please do let us know.
Peter Connick
  • April 13, 2025
Thanks Tyler. I spent a long time yesterday on FB talking to one of your colleagues who tried loads of stuff. Sadly no answer yet. Everything is set the same on both phones yet mine doesn't work.
Would it be possible to take roaming off my SIM from the UK and then put it back on? Just an idea.
As your colleague said, it could be a phone fault, so perhaps I should try Samsung.
Thanks for trying anyway.
Tom B
  • 8408 replies
  • April 14, 2025
Hi ​@Peter Connick
Okay, if you’re already in touch with our team on Facebook it’ll be worth keeping contact with them to get your issue sorted.
