No roaming left after upgraded.
Hello, I’ve just upgrade from a sim only contract to a contract with a phone. As soon as I made the transition I received a message saying I’d used 100% of my data roaming. I contacted the customer service team, and they mentioned they saw I still had all my data roaming. I am very confused, I just wondered if anyone else has had this happen? If so, how was it resolved?
Best answer by Matthew T
Hey @Lou251807,
As @swcq mentioned, we’re aware of an issue with the iD Mobile app displaying incorrect Data allowance. I’ve checked your account (and @swcq, but I believe he had flagged this previously) and shared with the relevant team to get it corrected.
You both have your correct contracted Data Allowance. This is purely a visual glitch.
  • Helpful
  • 31 replies
  • July 26, 2024
I have a similar problem my contract is for 100gb but shows only 20gb on the app,I'm guessing there's still problems with app
  • 1861 replies
  • July 26, 2024
Hey @Lou251807,
  • Helpful
  • 31 replies
  • July 26, 2024
That's fair enough thanks
  • July 26, 2024
Thank you.
  • July 31, 2024
I've  done exactly the same ( switched from sim only to contract) and got the same message.  Can't seem to open live chat to contact anyone about it @Matthew T
  • 1861 replies
  • August 1, 2024
@Alison Ruth - can confirm you have your 500GB allowance. Thanks.
  • August 1, 2024
Thanks @Matthew T   Any idea when the app will be working properly so I can keep a check on usage?
  • 1861 replies
  • August 2, 2024
We’re currently working on a fix, I don’t have an estimated rollout date yet unfortunately. However, I think you’d be hard pressed to use 500GB in a month!
Ian126
  • August 2, 2024
This has just happened to me, I have just upgraded and I recieved a message saying all my data has been used. The app is showing 106GB/50GB used? I upgraded from 36GB and have never been anywhere near the limit?
  • 8 replies
  • August 3, 2024
A similar issue I changed from 5Gb to 30Gb plan whilst roaming. First txt said plan changed, immediately followed by another saying I had used 100% of 30Gb roaming, impossible in 30 seconds on 4G
Ian126
  • August 3, 2024
Did you get this issue fixed?
  • 8 replies
  • August 4, 2024
No. Seriously unimpressed with ID mobile, impossible to contact anyone via website, chat or phone. I won’t be with ID for long if this is the norm.
Kate Wiseman
  • August 4, 2024
Thank goodness I've found this thread as I've just upgraded and got the same message. I should now have 50gb but it says I've maxed out my data at 30gb.
  • 1861 replies
  • August 5, 2024
@Ian126 @Denny 58 @Kate Wiseman - A fix has been rolled out for this. Thanks.
Peter Verelst
  • August 5, 2024
Just happened to me on both accounts I upgraded used your 30gb data allowance funny when one phone as not been out of Uk
  • 1861 replies
  • August 5, 2024
@Peter Verelst, thanks for sharing, when was the Plan Change done? Thanks.
  • August 7, 2024
Just had the same upgraded then txt to.say roaming has been used??
  • August 8, 2024
I’ve also received the same message after actioning an upgrade. I’m currently in France, but haven’t used anywhere near 30Gb since 1 August (and understand that France is currently limit free in any case).
I assume it is a glitch, but I’m wary of using too much data now in case I return to a massive bill!
  • August 8, 2024
Put a 0 cap on so your covered
  • 1861 replies
  • August 12, 2024
@Wlunn @thesandrock - please disregard the SMS if you recently upgraded or changed your plan. Thanks.
