Not receiving texts while abroad
  • September 5, 2024
  • 318 views
I am in Italy, full roaming enabled, I can use data, send texts, make and receive calls, but I do not receive texts from other Italian mobile numbers.
I have already tried all the suggestions in the other similar threads (switch off/on iMessage, restart, check phone number, switch manually to another roaming operator, ...), to no avail.
I have also switched my SIM and put it in another phone, with no change (so, the problem is not in the phone, it has to do with the SIM). My phone is a iPhone, the other an Android.
Is there anything else that I can try? Thanks,
Bob
  • 8369 replies
  • September 9, 2024
Hi @Bobspiders
Sorry to hear this, are you able to send texts to Italian numbers?
Is your bill cap at £0?
  • September 11, 2024
No bill cap, got unlimited texts and minutes, and yes, can send sms to Italian numbers, the problem is just in receiving
Hi @Bobspiders,
I would advise to firstly reset your network settings and restart the handset.
It sounds like everything is enabled on your handset as you are able to use other services.
Are you unable to receive messages from all numbers or just UK numbers?
Hi Kash, I coudn’t receive text from an Italian number. And I reset/restart the device multiple times, even swapping SIMs. Anyway, now I can’t test it any more, the phone is back in the UK … We’ll see next time, thanls for the help
  • 8369 replies
  • September 12, 2024
Hi @Bobspiders
Okay, was the text definitely sent from the Italian number’s side?
Sorry to hear we couldn’t get this sorted in time, if you have further issues, please let us know.
