permanent roaming - notificarion
  • January 14, 2025
  • 20 views
I’ve been working in a roaming destination for the past couple of months, and I am due to be working here for a little while longer before returning to the UK.
I understand that under the terms of the fair use policy, I’ll fall under ‘permanent roaming’ and incur charges. This is absolutely fine - I was just wondering if I need to notify the network of this or will it be detected automatically?
thanks
Best answer by Natalie W
Hello ​@Moore1982
Any extended time using the service outside of the UK will automatically be detected.
If you have any further questions regarding roaming, please take a look here
Nat
Forum|alt.badge.img+20
  • January 14, 2025
Hello ​@Moore1982
Nat
Reply.
