phone not working
  • December 18, 2024
  • 41 views
Rachey Ray Ray
Hi, my Internet is not working. My phone is not working. I’m in Portugal.
Daz_S
Gold Contributor
  • Gold Contributor
  • 1627 replies
  • December 18, 2024
Hi there ​@Rachey Ray Ray
Did you enable roaming on your iD account before you left the UK?
Have you swiped roaming on on your phone?
If the answer is yes to both of the above try manually searching for a roaming partner network, then of those (MEO, NOS, Vodafone) try connecting to the 2nd one down on the list. Once you get the automated rate advice text it should start working.
Rachey Ray Ray
  • December 19, 2024
Thank you, it’s all sorted now.
  • 3991 replies
  • December 19, 2024
Hey there ​@Rachey Ray Ray, thank you for reaching out.
Thank you for your kind support ​@Daz_S, and we hope all is sorted now :)
Daz_S
Gold Contributor
  • Gold Contributor
  • 1627 replies
  • December 19, 2024
Glad to hear that Rachey Ray Ray🙂
