please help: cant make international calls
Hi all
I confirm that I have set a spend cap and turned international calls ON on the app but im still unable to make calls to Iran. Can you please help? 🙏
I have tried so many methods to contact the team. Live chat button isn’t there, email gets back with an auto response that the mailbox is not monitored and there is no phone line.
im a pay monthly customer btw
Best answer by Mohammed
Hey @ThisisaNightmare
For international services, you need to enable the International toggle switch in the app and have a spend cap set apropriate to allow the chargeable spend which you’ve already done.
You also need to use the correct dialling code for ringing that country.
This is +98
Have a look at the following link below for some further info on this: https://www.prokerala.com/how-to/call/iran?from=united-kingdom
  • 7962 replies
  • May 30, 2024
This is +98
Dear @Mohammed
as I’ve clearly mentioned in my post, I have already done those. My spend cap is at 25 and have set international calling on in the app. I still get an automated message that the operator ‘ does not allow calls to this number’ whenever I make an attempt
  • 12167 replies
  • May 30, 2024
ThisisaNightmare wrote:
Dear @Mohammed
Have you tried sending a private message to iD support using Facebook Messenger, @ThisisaNightmare
This seems to be a good alternative when Live Chat has issues.
  • 8279 replies
  • June 5, 2024
Hi @ThisisaNightmare
Unfortunately calls from iD Mobile to Iran/in Iran are unavailable, we have no roaming agreement there, sorry.
  • May 20, 2025
On the mobile ID App go to Plan > Manage your ID services > International.
Toggle the bar. You may need to turn your phone off and turn on again before the service is activated.
