Previous network provider showing on phone when abroad, unable to receive calls
Forum|alt.badge.img
Recently joined iD on sim only, when abroad my previous network provider showed on my phone and was unable to receive calls
Best answer by Fishg
Thank you Tom, I will try that the next time I'm away, I'm on an eSim with Id but my old network is a sim, something so simple! Thank you for your reply
  • 8408 replies
  • March 7, 2025
Hi ​@Fishg
You may need to remove the old network’s SIM/eSIM from the device and insert only the iD Mobile SIM card.
Forum|alt.badge.img
  • March 7, 2025
  • 8408 replies
  • March 7, 2025
Hi ​@Fishg
No worries, let us know how you get on.
