problems calling from EU
  • July 8, 2025
  • 14 replies
  • 343 views
I am unable to call family on UK number while abroad in EU. Roaming internet is working and i can call local numbers and UK numbers located in U K but not my family numbers on holiday with me Roaming internet is working.
MZone
  • July 8, 2025
Are you using +447 or 00447?
  • July 8, 2025
00447
  • July 8, 2025
I have also tried +447 still the same effect . The call is ended automatically before the call is formed
My wife can call me she is with Lebara network in UK. It is very frustrating
  • July 8, 2025
I have used +447 as well with similar results the call is closed before any connection or ringing is made. My wife who has Lebara and daughter on smarty can call me with no issues
  • July 8, 2025
Further details, I can't call any UK mobile number located in UK or abroad. Can someone find a reason? I have restRted the phone several time. Pixel 7 pro AMD I have esim from ID
  • July 8, 2025
Hi ​@Casaubond
In the iD Mobile app, are roaming and international both checked on?
  • July 8, 2025
Yes, I have both checked. I was in EU in May and all worked ok. I have received a cal from ID service teams but I found it somehow dodgy. The guy said is because my esim is damaged somehow I need a physical SIM They asked for a price of £27.25 to have a SIM delivered... He did say it will be returned but I found it unusual. First I am a customer and already paying through direct debit, so if necessary 1 pound could have been retained. Secondly the sum was weird and it sounded like a payment. Why should I pay for it because ID som card is broken? It is not operator dependent
  • July 9, 2025
Hey there ​@Casaubond, we wouldn’t charge for a replacement SIM card to be sent, unless we were potentially sending it abroad, which I don’t believe we’d do. What was the phone number that rang you please?
In terms of the calling, are no phone numbers working at all?
Have you tried resetting network settings?
  • July 9, 2025
The phone was ,07871023398. I can call UK landline numbers an EU mobile numbers. The only numbers I can't call are the UK mobile numbers regardless if the owner is in UK or abroad in EU
  • July 10, 2025
Hey there, that phone number doesn’t appear to be an iD Mobile phone number. Please don’t give any further details to this number.
Where are you abraod please in the EU?
  • July 10, 2025
I am in Romania. I have been here in May this year, everything worked fine
  • July 10, 2025
Hey there ​@Casaubond, so to clarify, you’ve been in Romania since May and it was working fine until now? If so, what date did you get to Romania, and what date did the issue begin please?
  • July 10, 2025
I am sorry for the misunderstanding
 I have been in Romania for 5 days in May this year and everything worked as expected.
I have returned to Romania last week and I have noticed I can't call UK mobile numbers regardless if the phone is physically located in UK or in Romania or in Spain for example.
I can call UK landline, and EU landlines or mobile numbers. The Dara roaming works flawless as well.
Weird problem.
  • July 10, 2025
Hey there ​@Casaubond, not a problem, thank you for confirming those details for me.
Just to check, is your phone number showing correctly in settings? Secondly, have you tried restarting your phone, and also resetting network settings?
Also, what error do you get when trying to make a call?
Finally, are you able to receive calls okay?
