Receiving calls in Morocco
  • January 26, 2025
  • 71 views
Despite upping the cap on my account I can not seem to receive calls in Morocco. This is causing extreme issues not being able to authenticate via Microsoft. Any thoughts from the community? Many thanks.
Best answer by Kash
Hi ​@Vigggen,
The link below may help with your issue.
Can you please try and manually connect to Orange Morocco and INWI?
  • January 29, 2025
Hi ​@Vigggen,
  • January 31, 2025
Many thanks ​@Kash for the reply. Fortunately I managed to find the solution by manually setting the network as you suggested. It did the trick perfectly.
Appreciate you contributing to the community as ID Mobile were of little use- they even asked if I was on an island when I told that I was in Morocco! They were totally disconnected to reality.
Forum|alt.badge.img+21
  • 2144 replies
  • February 1, 2025
Thank you for getting back to us ​@Vigggen
We are happy to hear this has been resolved.
Please get in touch if you require any further assistance.
Nat
