Could a member of ID mobile please clarify the position with roaming in EU . Can I use up to my monthly allowance of 108GB or am I capped at 30GB. Many thanks
Roaming
Best answer by Tyler C
Hey there
However, currently, we’re running a promotion where you can use as much data as your usual UK allowances will allow. Therefore, for example, currently if you’re on 100GB data, then you can use up to 100GB data in EU countries too. This promotion is also shown via the link sent above.
Log in to the iD Community.
Social Login
Log in with FacebookPlease enter your email address. If it matches our records, we'll send you instructions to reset your password.
