roaming
How can i view how many days i have been roaming on my plan?
Best answer by Tom
Hi ​@JJGregory
Unfortunately not, if there’s any issues with fair usage, we’ll automatically be in touch.
Forum|alt.badge.img+2
  • Helpful Contributor
  • 55 replies
  • June 15, 2025
hi there
I asked a similar question of “ how do I know how much roaming data I have left” and I was met with the answer of
From 1 October 2024 and until further notice, all customers can use their full UK data allowance in Roam Free destinations*, at no extra cost! We’ll notify you when the promotion ends and when the 30GB Roaming data limit is reinstated.
- Anika”
It doesn’t seem like they have the ability to see how long you’ve been roaming for, nor How much data you used?
Forum|alt.badge.img+6
  • 560 replies
  • June 16, 2025
Hi ​@L0rdvega
Unfortunately there is not currently a way to track the usage used while specifically roaming, we’re feeding back the want for this feature, however don’t currently have anything to announce.
Anika
  • 55 replies
  • June 16, 2025
Anika wrote:
Hi ​@L0rdvega
Anika
Yes, I know. I wasn’t shaming you, I was saying that you can use the full UK allowence until further notice, so usage tracking is not needed
Personally you should keep the roaming allowence indefinately as it’s a massive selling point to have ID Mobile, people like to have big data allowences while roaming, so they don’t have to fear how much they’re using
  • 560 replies
  • June 18, 2025
Hi ​@L0rdvega
We’ll take this feedback onboard and feed it back internally.
Thank you.
Anika
  • June 19, 2025
Thank you for the replys, i wa more worried about the number of days roaming than the actual data used but i don't seem to see a counter for days actually using roaming.
  • 55 replies
  • June 19, 2025
I take it you’re on an extended holiday, Not just the usual one or two weeks.
I don’t have an answer for you unfortunately as I do mobile do not provide the information
  • 2396 replies
  • June 20, 2025
You’re welcome ​@JJGregory
Unfortunately this is not a feature we offer, sorry.
Natalie
  • June 21, 2025
Thanks for the answers,
Yeah i do a lot of weekends and weeks away in random smal blocks so it just gets tricky to keep tabs.
If there is no way to view this how can i stay within the fair usage policy?
  • 8756 replies
  • June 23, 2025
Hi ​@JJGregory
