I am in Italy and roaming is not working. This is the second time in the past 6 months. It was working perfectly till last December Roaming is on on app on phone , no change of phone. Nettwork set on Automatic, picks up Wind3. I have switched phone on and off multiple time without any improvement, any other tips and advise? I need the phone for working. Thank you
Roaming in Italy network not working
Best answer by WelshPaul
Please reset your network settings and try connecting to 3 ITA or WIND.
You can manually connect to both networks via your network settings.
Please let us know how you get on.
Rich Text Editor, editor1
Editor toolbars
Press ALT 0 for help
Log in to the iD Community.
Social Login
