Hi I'm currently in the US and I recently changed my cap to £50 and using mobile data still isn't working. I've tried doing the APN to change network but it isnt working and I've reset the phone multiple times. I've turned on roaming on both the phone settings and the ID mobile app but its still not working. Any fix?
Roaming not working
Yeah, with an eSIM capable handset, a data-only eSIM with a US travel plan is a better option than iD Mobile rates for roaming data in the US.
I’ve used a Soracom Mobile eSIM in the US, which worked well for me.
Log in to the iD Community.
Social Login
Log in with FacebookPlease enter your email address. If it matches our records, we'll send you instructions to reset your password.
