Hi I'm currently in the US and I recently changed my cap to £50 and using mobile data still isn't working. I've tried doing the APN to change network but it isnt working and I've reset the phone multiple times. I've turned on roaming on both the phone settings and the ID mobile app but its still not working. Any fix?
Roaming not working
Shaun Procter wrote:
Yeah, with an eSIM capable handset, a data-only eSIM with a US travel plan is a better option than iD Mobile rates for roaming data in the US.
I’ve used a Soracom Mobile eSIM in the US, which worked well for me.
Rich Text Editor, editor1
Editor toolbars
Press ALT 0 for help
Log in to the iD Community.
Social Login
