Suzi Griffin
Jul 30, 2024 1:37 PM UTC
roaming not working in Europe
I have not been able to connect in France or Belgium. I'm going to Germany tomorrow and I'm fully expecting the same problem.
I have turned on data roaming and I have more than enough data available and allowed WiFi calling. But can not connect to the internet or make or receive calls. When I try, I get an English message telling me that the call can't be connected.
This is extremely frustrating and I am SO close to changing my provider.
I have a OnePlus phone. The same thing happened last year when I had a Samsung. So it's not the fault of the phone.
Thanks in anticipation for your support
Suzi
    Matthew TAnswer
    Aug 5, 2024 9:19 AM UTC
    Hey @Suzi Griffin,
    Did you figure out a resolution? Is Data Roaming enabled on both your phone AND in the iD Mobile app?
    Matthew TAnswer
    Hey @Suzi Griffin,
    Jul 7, 2025 6:48 PM UTC
    I have data roaming on, switched my phone on/off and it still does not work. It worked in Iceland a short while ago.
    Jul 7, 2025 6:59 PM UTC
    Hi ​@Leopard69
    Which device are you using?
    Anika
    Jul 7, 2025 7:01 PM UTC
    It's an samsung s22
    Helpful Contributor
    Jul 8, 2025 7:41 AM UTC
    Is the roaming enabled in the ID Mobile app? Weirdly it is off by default
    Open the ID Mobile app
    Click Plan on the bottom
    Go to Manage ID Services
    Select roaming
    I used my roaming in Spain and Latvia in literally the last month with no issues
    Jul 8, 2025 11:22 AM UTC
    Hi ​@Leopard69
    Have you checked as ​@L0rdvega suggests? It could be switched off in the app.
    Dec 4, 2025 7:06 PM UTC
    I have just had the exact same problem in France and Belgium. Roaming is switched on in the app and on the phone but nothing. I used a Lebara sim and it worked perfectly as did giffgaff and Lyca. I have decided  it is time to leave
    Apr 9, 2026 6:34 AM UTC
    Did anyone get a solution to this? Just wait it out? I have tried everything to reset mobile data and kinda need it abroad. Any help would be great :)
    Apr 9, 2026 6:47 AM UTC
    Same issue here. I'm in France and it's just stopped after 4 days of being fine. No fixed work, both Samsung and ID related.
    Apr 9, 2026 9:00 AM UTC
    Hi ​@CourtneyHJH, ​@Awrah,
    We're aware that some customers are unable to use Mobile Data (4G/5G) abroad. Our team is working with our network partner, Three UK, to fix this as soon as possible.
    While we fix this, you can try switching your phone to Airplane mode for 60 seconds. Turn it back off after the 60 seconds are up, and your mobile data should reconnect.
    We're sorry for the disruption and thank you for your patience.
    For the latest updates, please visit our Service Status page for details.
