Roaming text says I am in the wrong country
Molly Rugg
I am on holiday in Greece (Kos) and received a text to say welcome to Greece but then received another one to say welcome to Turkey. Turkey is chargeable, does anyone know how I can change this back?
Best answer by JoeKing
@Molly Rugg  You may have to go into your phone's network setting and manually search for a supported network and select it.
As I understand it these were/are supported networks for roaming in Greece for IDMobile.
ID Mobile roaming in Greece uses the HELLENIC TELECOMMUNICATIONS ORGANIZATION S.A. (OTE S.A.), Wind Hellas, and Vodafone Greece networks. Specifically, you may also connect to Cosmote and Nova in Greece, according to the iD Mobile community. All iD Mobile plans include inclusive EU roaming, allowing you to use your data, texts, and minutes as normal in Greece, up to a fair usage limit.
Joe
JoeKing
Silver Contributor
Forum|alt.badge.img+11
  • Silver Contributor
  • 498 replies
  • May 18, 2025
Joe
  • 8395 replies
  • May 20, 2025
Hi ​@Molly Rugg,
Please can you try the steps that ​@JoeKing advised and let us know how you get on.
