Roaming to Netherlands & Germany
Going away for 5 days soon. 1 day Netherlands & 4 days Germany. Not been abroad since switching to iD.
Any advice at all ? Seen some people have glitches.
Anything specific to do before I go ?
When I arrive ?
Fair usage ? How much, ?
probably going to use maps & WhatsApp a lot.
Best answer by MZone
Have a look at this page here. If you have any further question after checking that out please come back to us.
You can also put a £0 spend cap on your account to avoid any unexpected charges.
MZone
  • 1190 replies
  • April 23, 2025
  • 8369 replies
  • April 23, 2025
Hi ​@D-ice95
I’d recommend the same as ​@MZone above, as well as the following;
https://www.idmobile.co.uk/help-and-advice/roaming-advice
If you do notice any issues with networks whilst abroad, I’d recommend connecting to networks manually instead of using the default automatic network connection.
  • April 24, 2025
HI, thanks for advice.
Eventually I found the bill capping on the App in ‘Bills’ then ‘manage bill cap’.
I can't adjust the APN settings, looks like my iPhone 12 Pro Max can't receive OTA updates ?? That doesn't seem right. I was offered another menu, but it's way too confusing & don’t know what i’m meant to be changing.
The instructions online, seem to be using a different language to the App language & terminology, so thats making things trickier.
Still a bit confused.
MZone
  • 1190 replies
  • April 24, 2025
APN settings for iPhone should be pre populated so wouldn’t worry too much about that and they are locked down on IPhone so you can’t amend them anyways.
  • April 24, 2025
Ok, thank you Mzone
