Travelling in Turkey
Elena Jane Arnaudova
I can’t find Turkey on either of the ID roaming lists! Please can someone tell me the best and cheapest way for my daughter to use Internet/data on her phone whilst in Turkey. She will be there for two weeks. I would like to be able to keep in touch via What’s App and she needs to use Internet for work/study also.
Okay @Elena Jane Arnaudova, maybe get a local SIM card upon arrival in Turkey, or if your daughter has an eSIM capable handset, perhaps consider buying a data-only eSIM for travelling, before leaving the UK.
https://airalo.com/turkey
https://roamless.com
FYI, the iD roaming charges for Turkey are:
  • 12167 replies
  • July 8, 2024
  • 3801 replies
  • July 22, 2024
Hey there @Elena Jane Arnaudova, welcome to Community!
Charges for roaming in Turkey can be found below:
Thank you. We’ve bought an unlimited eSIM with Holafly. It seemed a better option than the others which had data limits.
