unable to turn on roaming
  • September 16, 2024
  • 406 views
Alessia Borys
I am abroad and am trying to set up so I can use internet / roaming but the tutorial for how to enable it is incorrect neither the app or the online account has any “extra” etc
and the link I got when I landed abroad from iDmobile doesn’t load
Best answer by raabsfrank
Hi Alessia, can you try these following solutions
  • Enable Roaming on Your Phone:
    • iPhone: Settings > Mobile Data > Mobile Data Options > Data Roaming.
    • Android: Settings > Connections > Mobile Networks > Data Roaming.
  • Enable Roaming via iD Mobile:
    • App: Log in, go to Settings or Account Settings, and look for "Roaming" or "Manage Extras."
    • Online: Log in to the iD Mobile website, go to My Services or Manage My Account, and enable roaming.
  • Manual Network Selection: Go to your phone's Settings > Mobile Networks > Network Operators, and select a network manually.
I hope this will work for you and if still facing same issue then you should generate ticke on support portal……
  • September 17, 2024
  • 8352 replies
  • September 19, 2024
Hi @Alessia Borys
Sorry to hear this, have you tried the above from @raabsfrank?
Have you tried resetting network settings since roaming?
Where are you roaming?
