US ROAMING
  • February 19, 2025
  • 6 replies
  • 152 views
  • 6 replies
Hello
few questions about roaming in the US:
  • Is there any limit of time of staying in the US for the roaming to work?
  • Are you getting charged to receive text in the US?
  • If you deactivate Data Roaming in the iPhone mobile service setting, are you still able to receive call and text in the US?
Many thanks
I’d say, provided you continue to pay monthly for your iD plan, there shouldn’t be a time limit on using your iD SIM overseas, outside the iD roam-like-at-home destinations (EU), ​@G3000
Just a note to say, using your iD SIM in the USA for calls, texts, and data would be expensive.
  • 12559 replies
  • February 19, 2025
Okay ​@G3000, SMS text messages are free to receive in the USA.
Calls and SMS text messages should work even with roaming mobile data turned OFF.
If your iPhone is dual-SIM with eSIM capability, a data-only eSIM with a travel plan for the USA might be an option to consider.
  • 6 replies
  • February 20, 2025
  • Is there any limit of time of staying in the US for the roaming and the sim to work?
  • I read many about many people having issues with roaming in the US. Is this problem solved?
many thanks
  • 12559 replies
  • February 20, 2025
Sorry ​@G3000, can’t say with certainty you wouldn’t experience issues roaming with your iD SIM in the USA. I’d guess as an iPhone owner, issues roaming in the USA are less likely in general.
This community article may help.
  • 6 replies
  • February 20, 2025
thanks. Is there any limit of time of staying in the US for the roaming and the sim to work?
  • 12559 replies
  • February 20, 2025
  • 2396 replies
  • February 21, 2025
Hello ​@G3000
It looks like ​@andewhite has been able to assist with your query.
Please do reach back out if you require any further assistance.
Nat
