Using data abroad
I am travelling to Dublin, Belfast, Porto, Croatia and Greece in the next month for work and holiday. I have data roaming turned on. Is there anything else I need to do or will the data automatically be available in those countries when I arrive ?  Reason I ask is that I’ve been abroad before with data roaming turned on and it’s not worked and I’ve had to get e-SIMs. Am I missing something ?  Thank you.
One reason it may not work is the handset gets an incorrect APN value, when connecting to an iD roaming partner network.
The correct APN value is “id”, in lowercase, @Buffers75.
Sometimes performing a NETWORK RESET on your device will fix the problem. Calls and SMS should work regardless.
  • 12548 replies
  • June 1, 2024
  • June 1, 2024
Many thanks @andewhite I will give that a try next week and update on here 👍
  • 8645 replies
  • June 6, 2024
Hi @Buffers75
I’d recommend the same above as @andewhite, as well as this handy page for roaming advise.
https://www.idmobile.co.uk/help-and-advice/roaming-advice
  • June 16, 2024
I’ve followed all the instructions but I don’t get the option to add the APN information and nor can ID mobile send me the config settings as my device is not setup to receive them. I have an iPhone 11 so quite old now. Randomly in Porto my 4G didn’t work for data until I was at the airport ready to fly back to the UK 🤦‍♂️.
I think I may have to buy an eSIM from Roamless or similar for my trip to Croatia and Greece.
Thanks for all the info. At least I guess I know now I have tried everything.
  • 8645 replies
  • July 3, 2024
Hi @Buffers75
I’m sorry to hear that, resetting network settings typically helps in setting the correct APN settings, if you aren’t able to change them manually which we appreciate may not be changeable.
