I am travelling to Dublin, Belfast, Porto, Croatia and Greece in the next month for work and holiday. I have data roaming turned on. Is there anything else I need to do or will the data automatically be available in those countries when I arrive ? Reason I ask is that I’ve been abroad before with data roaming turned on and it’s not worked and I’ve had to get e-SIMs. Am I missing something ? Thank you.
Using data abroad
One reason it may not work is the handset gets an incorrect APN value, when connecting to an iD roaming partner network.
The correct APN value is “id”, in lowercase,
Sometimes performing a NETWORK RESET on your device will fix the problem. Calls and SMS should work regardless.
Log in to the iD Community.
Social Login
