Using data roaming - what happens if I go over allowance, will my preset cap work? | iD Mobile Community
Answer
  • July 9, 2024
  • 215 views
Hi, pretty much as mentioned in the title:
I set a cap of £5 on my sim when originally setting up. If I use my sim abroad, and exceed my roaming allowance 30Gb will the data cut out after using the additional £5 cap? I don’t want any nasty surprises in the bill department when I get back! Thanks
Okay @Hotdog, that's exactly what should happen with your iD account bill cap setting.
  • July 9, 2024
  • July 9, 2024
Thank you for clarifying! :-)
  • July 24, 2024
Hi there @Hotdog, thank you for reaching out.
Thank you for your advice @andewhite, we hope that was able to help @Hotdog.
Thank you :)
