using ID Mobile in France..
Pete2000
Helpful Contributor
Forum|alt.badge.img+1
Are there any issues using my ID Mobile plan in France ? I have read about some mobile data problems in the past, thanks in advance.
Best answer by MZone
France is one of our free Roaming destinations which means that you can use your monthly data allowance and add-ons at no extra cost, up to 30GB. Make sure you connect to Societe Francaise Du Radiotelephone, Bouygues, Orange or Free Mobile as they are the roaming partners.
MZone
  • 1268 replies
  • March 31, 2025
Pete2000
Helpful Contributor
  • Helpful Contributor
  • 26 replies
  • March 31, 2025
Great thanks
