using ID sim outside UK
Can I know if I can use my ID sim outside UK in Albania? If yes, will it be the same rates? Can I use it like I use in the UK or it will be different?
many thanks
Best answer by Geluk
Yes you can, but charges will be higher than here obviously.
Search id Mobile's webpages re ROAMING.
Geluk
Silver Contributor
Forum|alt.badge.img+10
  • Silver Contributor
  • 469 replies
  • July 31, 2024
  • 8484 replies
  • August 7, 2024
Hi @Arya
You’ll be able to use your iD Mobile SIM card in Albania, however extra charges will apply according to your usage, we’d recommend checking the below;
