Using my phone in Poland | iD Mobile Community
  • October 3, 2024
  • 481 views
I'm going to Poland for a few days at the end of the month - I don't plan to be using my phone for calls or texts, but I generally use mobile data when out and about (Google Maps, WhatsApp, etc.).
Is there anything I need to do prior to going to ensure I will be able to do this while abroad, or will it connect OK to another provider out there? Also, is there any additional charge or cap to using mobile data in Poland that I should be aware of? If so is there a temporary bolt-on or package I can buy for the few days I'm over there?
Best answer by Matthew T
@Rorulon -
Poland is included so you can use up to 30GB data out there as per Fair Usage Policy: https://www.idmobile.co.uk/help-and-advice/eu-roaming/fair-usage-policy
Here’s how to enable Roaming.
  • October 8, 2024
@Rorulon -
